Results 1 to 1 of 1
Thread: Hardox weapon bar
    Got too many bits of metal in the garage. 25mm thick hardox 500 weapon bar. This is the spare bar from Crossfire which surprisingly we didn't need. Never been used or spun. Still got the tape on from when we were spray painting it!
    Just shy of 1m tip to tip with a weight of 22.8kg. Moment of inertia is 1.75Kgm^2. Some rough values of KE based on bar rpm,
    1000rpm - 9.5kJ
    1500rpm - 21.5kJ
    2000rpm - 38.4kJ
    2500rpm - 60kJ
    3000rpm - 86.2kJ
    It is balanced (statically) and ready to bolt on. The 4 bolt holes are 14mm dia with the central hole being 30mm dia.
    £250 incl UK delivery.
    Any questions let me know. Pictures below.
    https://imgur.com/a/WVIdM
    Edit - just to add, the profile was plasma cut with the holes in the center being drilled for precision. The tips have been gently ground back to remove the heat affected zone
