Hey all,
Decided to untangle and disassemble the Argos 14.4V drills I used in my demo bot.
In making the demo bot, I removed the battery and unscrewed the few screws holding the two sides of the case together.
In the demo bot I simply took the wires off the trigger and routed out the back. After closing the case again I used it in that state.
The battery could be easily repurposed too, this was used in the demo bot. There is a power connector which you can wire to. Should you wish to use these batteries.
This was all done back in November. Now that Evil K'Weevil (EKW) is almost ready, I took the test bot to pieces. Thought I would also look if the motors are any good and understand if they can be reused in a Featherweight.
Continues....
