Does anyone know where I can pickup a mount for an MFA 940D which I picked up from Maplin ? Thought it came with a mount but apparently not. MFA website doesn't list it. The gear box has a diameter of 32mm the motor 27.5mm, the gearbox has 4x equally spaced mount points. Hard to get centre point but think they are 20mm apart. The spindle enter a protruding elongated circle/rounded rectangle as typical. Width across straight edges 17.9mm and diameter across rounded ends 19.8mm.
Haven't really got to grips with the standard sizes yet so not sure what is compatible. Any tips here too would be great!
I could try and fabricate them but the effort for a cheap part with better finish just doesn't seem worth while.
Thanks
