Results 1 to 3 of 3
Thread: Incontango Build
    How does the motor not slide back and forth in the bracket if it isn't screwed in on the face of the gearbox to the panel? I'd probably have a peg or something to hold the motor in at the rear to prevent that.
    Otherwise, looks sturdy enough though how thick is the bracket? On The Honey Badger 2.0, the mounting brackets were 1mm thick steel which bent out of shape too easily. The Honey Badger 2.1 uses 4mm thick steel and they've held up remarkably well given all the flips it has had.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
