Results 1 to 9 of 9
Thread: Noob alert. Basic question #1....
Hybrid View
    For a basic featherweight, either voltage is good at this stage (though more is better) and I guess either battery is also fine for this application though 800mAh is fairly small, they can be changed later on if you decide to go further into this and into competition - my Featherweight uses 2.1Ah batteries in series and my Beetleweight uses a 1.5Ah battery. I can't say how long the Beetleweight battery lasts in combat but the Featherweight will run 2 matches before needing a charge and that is with it zipping around everywhere.
    BW: Shu!, The Honey Badger
    The good thing about using two drills however is you will double the capacity if in parallel.
    1.6Ah would last you a 3 minute fight in the tests i done for the school kits i produce. It depends on other factors such as wheel size, however i found for the setup i use, each battery adds around 2 minutes of fight time to the setup.
    I am new to this too. End of last year I tried a test with some 14.4v Argos drills on a test rig worked fine once unsorted out how to keep wheels attached. I used it as a proof of my skills and I have no intent to use that hardboard chassis, but the drill motors were impressively fast. If I use them for a real robot I would look at taking them out the casing and using a clamp to hold in place the ties suggested in the manual do not allow accurate alignment.
    Just remember you can't use the batteries in the new 12v Simple Value Argos drills, they use some weird lithium chemistry that isn't approved yet. You could check with your event organiser, but it might be best to go with Nicads if you plan on using the drill batteries, most lithium ones aren't approved (aside from DeWalts with their a123 LiFes iirc). For reference, My featherweight has a 3.1Ah battery but that's just because I have an abundence of space and weight left.
    Theo, for all classes, most LiPo's are approved by the FRA and subsequently the event organisers.
    Team RCC used 5000mAh and 8000mAh "el cheapo" Hobbyking LiPo's in Bullfrog, and never had any organiser objections.
    Our feathers and raptors , again, cheap Hobbyking LiPo's, and no problems whatsoever.
    Just follow the rules on fuses and battery managment, and you can use most commercial/RC LiPo batteries.
    I was surprised at how cheap LiPo's are. They sound a bit scary and it's new terminology 2S 4C etc. but not that complicated, plenty of sites and threads explaining it. Though you are on a budget perhaps they are still worth a look. But you will need a charger (and some on ebay ship without a mains charger) and a safety bag to comply with regulations. Also a fuse is mandatory in a LiPo system (but I'd fit one even if not).
    What Mario said
