Clearout! selling off some robot parts to make some money, and some space, for other robot parts.
Uk mainland delivery included unless stated.
Collection is from UB4 hayes
SOLD!! AWAITING PAYMENT
2x Ampflow A28-400
specs here
£500 for the pair
Bought second hand and never used
Brush holder casing is cracked, and shaft keyway is slightly damaged. This should not affect performance...
2x Ampflow E30-400 (24v)
specs here
UK supplier here
£160 for the pair
I bought these from Rapid electronics because I needed gearboxes quickly! these were removed and never used.
like a bunch of fans
£5 for 2 fans...
Everytime I get an ampflow motor with these fans on, the first thing I do is remove it and put it in my pile of ampflow motor fans.
I have like 20 of the things.
I know somepeople prefer to leave them on the motor, so if you would like some spares hmuuuuppp
Makita drill motor
£15 for the mystery bag!
I took apart a drill and threw out the housing because... im not really sure... I think I wanted the chuck? anyway, the contents of the drill went into this bag.
it was the type with the orange battery with the stem, not the new slidey one if that helps.
Ampflow E30-150 24v
specs here
uk supplier
£50 each (£140 for the 3)
Brand new.
I needed more gearboxes...
Bearing housing
£15 for the 4
aluminium bearing housings for 608-z bearings (skateboard, 8mm shaft)
made to dwg attached
massive low pressure cylinders.
for robots, or maybe you want to build your own arena? or lift a car or something?
part numbers are there for cad and weights etc.. I think from memory they were like 20kg or something.
I have 2 of each. open to offers
