Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Beetleweight Brawl 2018 (unofficial thread)
  1. #11
    turnigy 22260 3000kv 650v and hobbyking 60a sbec
  2. #12
    Sure it is the motor beeping? More likely to be the ESC (not clued up on this Brushless tech yet so could very well be wrong :P). The ESC manual suggests that there is no throttle signal being received (1 beep followed by a pause).
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  3. #13
    you sir, are a genius. didn't know there was a manual, just found it. Lemme have a look as its not that type of beeping, its a really quick one
    its something to do with the throttle not being in the lowest position, will try to find the correct channel and mix. Problem solving people!
  4. #14
    From the manual, looks to be that you need to reset the throttle position and set the pull rod to the lowest position.
    FW: Azriel
    MW: Jibril, Kaizen
  5. #15
  6. #16
    Nah, its a bit of a long story. Ive got a pair of 30a also and there absolutely fine. Ive heard good things about afro's so lemme know how you get on!
  7. #17
  8. #18
    You'll see for yourself come the 10th no need to let you know
    sounds good/threatening haha
  9. #19
  10. #20
    just the thought of a spinner is threatening enough :P i just want to meet people, have some fun and see some good fights. Not fussed about getting smashed lol
