Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 132
Thread: Team Kaizen - Kaizen
  1. #101
    I would take overvolted scooters over e30-400s cheaper and less burny
  2. #102
    Interesting, did not know they were prone to burning up. I did briefly consider fitting one to the axe but it would overrun the main section of the robot if I did that without a bevel gear.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  3. #103
    Have been very impressed at how this build log has gone. Nice work!
  4. #104
    Triceratop
    Guest
    Hi Michael,
    Good luck at Chatham.
  5. #105
    Thanks Eoin and Cliff! Hopefully it'll come back in one piece. :S
    Spent a bit of time rewiring the robot today so it is neater in there, important as space is at a premium in here.The 8S battery set takes up a lot of room, as does the Cytron ESC. Still, I hope to have it running soon to get some practice in driving it.
    FW: Azriel
    MW: Jibril, Kaizen
  6. #106
    Haha, oh boy....
    Have you seen the lineup, looks gruesome to say the least
    Kaizen does look really solid though, plus will probably absorb many hits, good luck!
  7. #107
    I've not seen any pictures of the competition so a complete shot in the dark. XD I expect Kaizen to come out with some battlescars.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #108
    Stay tuned.... you’ll see what the playing field’s like. In fairness, we’ve got a fantastic blend of different classes to really show off middleweights as a whole, couldn’t be prouder to see them all
  9. #109
    Well here we are, 31.2kg of Kaizen 1.0. The good news is that it moves fine, even on a very uneven wooden floor. Bad news, the pinion gear for the axe has slipped off again so I'll get that reseated back on the shaft and then I might actually have a weapon for Chatham. :P I'd say ~10mph which isn't fast but the small wheels mean it does at least get up to speed quite quickly.
    FW: Azriel
    MW: Jibril, Kaizen
  10. #110
    So Kaizen is ready as it will ever be. At the last minute, I fitted a 10mm thick polycarbonate wedge plate, primarily to square off the the side armour panels but also to deflect the ubiquitous spinners in the event. Held in with M8 bolts (of course) so should handle a fair bit of punishment in theory. The rear I've left as is but I'll bring a panel of HDPE just in case.
    Only trouble is, on the uneven dining room floor, I may have set the wedge too low so it might catch on the arena floor. I'll find out during the event I suppose (Dremel at the ready :P). I've also added some extra weight/reinforcement to the axe arm but after Chatham, I am likely to rebuild the axe completely.
    FW: Azriel
    MW: Jibril, Kaizen
