Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 112
Thread: BOB FW Series
  1. #101
    I'd recommend something thicker, like the thread cutting oil that Colin mentioned. WD40 is probably going to be too light for this.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
  2. #102
    Get yourself some CT90 available from toolstation. Its good stuff i use it on steels and aluminiums when tapping and drilling. Works well for cobolt drills and hardox too.
    https://www.toolstation.com/action-c...g-fluid/p61138
    Screwfix have an aerosol spray for £6.99, screwfix have the WD-40 brand of cutting fluid.
    https://www.screwfix.com/p/wd-40-cut...il-400ml/679gy
    Ideally get some of this: https://www.ebay.co.uk/itm/PACK-OF-2...0AAOSwx1ReNKuH is a 2 bottle pack, but this is the stuff. This isnt a spray, so its much more economical than spraying generally.
  3. #103
  4. #104
    McMullet
    Guest
    Hah, seems like what you have there is a steel bar bender! Look forward to seeing new BOB. Shame to think of BOB3 getting "retired" though, always thought it was a bit of a silent assassin at Robodojo, maybe didn't look as flashy as some but always put on a good show!
  5. #105
  6. #106
  7. #107
    Depends on the steel but in general, yes, they are stronger. I tend to use 10mm thick bolts as my locking bar.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #108
  9. #109
  10. #110
