Page 20 of 30 FirstFirst ... 101819202122 ... LastLast
Results 191 to 200 of 295
Thread: Team Kaizen - The Honey Badger
Hybrid View
    I am quite happy to come up to Manchester in the weekend if that makes it easier for you, I can drive.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Yeah that's cool, I'm free today and Monday, but working tomorrow, I'll pm my number and we can sort out a when and where
    I've reorganised the internals and whilst I may need a new battery case to fit the 4x batteries in the one case, I've finally got the internals organised in such a way that the lid finally shuts. My new OrangeRX Tx6i transmitter arrived today as well but I've yet to wire it in, I want to spend a bit of time learning about it first before converting The Honey Badger over to it. I very much approve of the semi-transparent orange.
    The new JR extender wires also arrived so one was plucked out, the positive wire clipped and the FeatherTwo now works with the current setup, many thanks to Rory for the wiring tip. I don't know if it is standard behaviour because of the wiring calamity last week or so but the ESC makes a whining noise when on, doesn't seem to affect how it works so I'll take it. I know it still needs rewiring properly, it is on my list of things to do.
    Anyway, here is a video of it terrorising the vacuum cleaner. :P
    FW: Azriel
    MW: Jibril, Kaizen
    So with the robot now nearly refitted, I've been working on getting the OrangeTX system plumbed in and after a bit of failsafe craziness, it now runs on it along with one of my Antweights.
    Today though one of the TZ85A needed reflashing again. Not entirely sure why, seemed to only be working at half power and developed a mind of its own when the transmitter was turned off. It is cured for now but something tells me it'll be back. I also tidied up my links and got the wiring ready to accept a fuse for the lifting arm or axe which I've put together, a sharp pointy steel thing on the end of a length of HDPE, I fear it may bend sidewards under use but there is still time to reinforce it.
    Many thanks to Retroman for the 14mm thick piping, I don't think I'll have it installed by Manchester but Grantham... perhaps.
    I do like Gimson's stuff but the hubs are a bit of a pain when either the grub screw bends or the hub itself deforms under load (they being Aluminium alloy, might go shopping for steel hubs next time there is any money to put into this - got Kaizen to work on after Manchester. Still, I put it down to extraordinary use on the arm, the hubs on the wheels are still good.
    FW: Azriel
    MW: Jibril, Kaizen
    Important news - the new front lid now has googly eyes!
    I've since added a locking pin arrangement for the arm and reinforced the substructure holding the motor onto the lid so rather than using 2x M4 bolts, 3x M6 bolts + 1 M4 bolt hold it in place. I've also began work on the front Aluminium bash plate replacing the metal door finger plate from last year that was shredded at Maidstone 2017 (DoubleTrouble was kind enough to donate some 5 bar tread plate at Gloucester 2017). I've bent it into shape but still need to trim off the excess to make it flush with the bodywork, the excess may replace the sticky tape eye brows
    FW: Azriel
    MW: Jibril, Kaizen
    Well, the 2.2 refit has been a while coming. It has been 116 days since the 12th of December 2017 when the refit technically started and there has been a few setbacks (largely of my own making) but finally, The Honey Badger 2.2 is completed!
    The lifting arm is now interchangeable with an axe attachment which although the motor is not ideal for such an application, works as well as I can expect and if I do end up doing a 2.3, that will be the main change. The white safety tether looks slack in the picture but it tenses up as it goes down and should do the job here.
    You'll note the large slab of Aluminium for better impact protection this time around and the much thicker and larger side wings being made out of 4mm steel so hopefully being flipped up and over will be a thing of the past.
    Internally, apart from the added weaponry wiring, not much has changed apart from the switch over to a OrangeRX system which I am readily getting used to but I do still need some more driving time with it. The armour is still 10mm HDPE with 3x 40mm Oak chassis crossmembers along with the 5 bar tread plate at the front and sides.
    There are still tidying up jobs to do, notably the front plate bends over too far grounding out one side of the robot on the floor but that is a 10 minute job to cut off the excess and tidy up so not too concerned yet. I'll see if I can get some videos of it running around tomorrow.
    FW: Azriel
    MW: Jibril, Kaizen
    And here is a video of the testing I did today with it. Perhaps the most important one here is get some threadlock on the nuts.
    Otherwise still as uncontrollable as ever.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #8
    at Manchester we need to a axe off with Broadaxe =D, now of any other axe/hammer bots going ?
  9. #9
    Quote Originally Posted by Maxamuslead View Post
    Why me specifically? :P
    I think there's a good 7 or so axe/hammer likes going at the last count, if Team Arc and Team Panoramic are also bringing theirs as I've heard on Facebook
  10. #10
    Quote Originally Posted by qbnut View Post
    Because i love you..... more the fact i didn't know who else was bring axe bots
