Page 12 of 30 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 295
Thread: Team Kaizen - The Honey Badger
Hybrid View
    We are going to Gloucester! Mounted the Tupperware box onto the base plate, mounted the new mounts onto the plate, eventually managed to get the motors in though be assured, 2x Gimson 13.7:1 motors + mounts on a 250mm wide panel is a tight fit and motor holes drilled out and wheeee!
    The Honey Badger is now so much more controllable than last time, must be the weight pressing on the back wheels to allow the motor's power not to go to waste. If anything, it has become a little twitchy but I'll take that over spinning drive wheels and no traction. Managed to lunch a castor ball at the community centre though so that will need replacing but in short, the robot will be at Gloucester for the Saturday.
    BW: Shu!, The Honey Badger
    FW: Azriel
    MW: Jibril, Kaizen
    Great to see everyone at Gloucester! I was only able to attend for the Saturday but had good fun in the arena with The Honey Badger 2.1. The fights finally saw the robot moving properly, damned zippy when it wants to be.
    I definitely need more practice time driving the thing. The tank controls make the robot sensitive to how much input I am giving at any one moment and it does mean that it prone to rushing before the squishy meaty thing behind the controls realises it and boom, in the pit. Also, it needs a weapon capable of self righting it, considering a axe at the moment. Not much in the way of damage though the flail went missing after the first fight, as did my link cover. The wheel came off at one stage and one of the chisels is bent but nothing a good whack with a hammer won't fix.
    I missed recording the first melee but I have videos (which are not very good) for the rest of the FW melees on Saturday.
    Excellent to see FW robots like BattleAxe, Venator, Mutiny, Luna-Tic and Bruiser at the event, many thanks to the Mutiny team for the Aluminium check plate, I'll look to use that in rebuilding the front wedge after Maidstone.
    FW: Azriel
    MW: Jibril, Kaizen
    Good to see you at Gloucester! Honey Badger doesn't half shift when it needs to
    Many thanks, first time it has really driven properly since being built. It was great to see you there as well, hope you managed to get a new chain for your axe.
    The Honey Badger was in bits again today, the flange screws holding the motors in have bent and the Tupperbox, perhaps unsurprisingly, has cracked (needs more screwing down in places to spread the load). The grub screws for the wheel hubs have bent again but nothing that can't wait until after Maidstone. However, considering it needed major surgery after Stevenage, Team Kaizen is living up to the name! :P
    Will be hamming things back into a straight line and teaching myself how to drive the thing properly if the weather holds out tomorrow.
    FW: Azriel
    MW: Jibril, Kaizen
    So The Honey Badger is back together and, save sharpening the chisels, straightening the front wedge plate so it looks respectable and charging the batteries, is ready to go again. For a active weapon though, I've been re-watching various episodes of Robot Wars and recapping the opponents from Stevenage and Gloucester to see what I could feasibly build.
    I've decided on a axe and I want to see if I can build a reciprocating mechanism for it (in a similar vein to Mortis, which you can see in action in the first fight of the War of Independence episode of RW Series 4). Whilst I am sure I'll lose some punch in the axe because of the losses in the mechanism, I am convinced that it'll pay off because it'll hit faster because it can repeatedly fire without me needing to hit a switch.
    This won't appear until 2.2 but so long as I get the linkage measurements right, it should work quite well.
    FW: Azriel
    MW: Jibril, Kaizen
    Wouldn't to crank mechanism like this do the trick coupled to an linkage or another crank do the trick ?
    I had trialled something similar in a static model before hand but I wasn't sure how the measurements would pan out but essentially, yes, it is going to be that sort of mechanism.
    Wikipedia (reference) describe the mechanism as a crank rocker mechanism, which handily show where I've been going wrong with my linkage length between the motor and the axe arm. I need to get a higher geared motor though, the 12v Como 50:1 motor is neither powerful enough and is too quick for this application.
    FW: Azriel
    MW: Jibril, Kaizen
  8. #8
    I think you'll be better off mocking it up with some cardboard and some paper fasteners. That's how I'm personally laying out the plans for my reciprocating axe mechanism for Ratatoskr.
  9. #9
    The static model I referenced to was literally a old metal bracket, a motor and some cardboard with bolts holding it together. The motor quickly ate the linkages but here we go:
    Deadliest weapon in the world right there :P
    FW: Azriel
    MW: Jibril, Kaizen
  10. #10
    What about something like a Whitworth Quick Return Mechanism ?
