Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Questions About 200A (or more) Brushless ESCs
    R9000's Avatar
    Roboteer
    Anyone have any experience with the Hobbyking Turnigy Monster?
    https://hobbyking.com/en_us/turnigy-...___store=en_us
    I'm looking into running some of the SkyRC Toro motors at 9 or 10S, and I need an ESC that will manage (the SkyRC Beasts won't cut it). The reason I ask is because the Hobbyking page says this:
    WARNING
    This is an R/C plane/heli only ESC. Do not attempt to use it to power car, buggy, skateboard, go-kart or similar machines. The programming logic is only designed for R/C Planes and Heli and will burn if applied to other devices.
    This makes little logical sense to me. Is it that the ESC can't handle large current spikes or something, or are they just trying to cover their butts legally? If this isn't a good choice, does anyone know any other reasonably priced 9 or 10S 200A ESCs? Cheers.
    That disclaimer is just so they don't get loads of people trying to return them after they blow them up trying to run electric bikes or skateboards. As long as you understand what you are doing its normally quite hard to break them.
    The main thing is to not have your battery wires too long or the inductance of the wire causes a voltage spike which blows up the MOSFETs on the board. So long as you run them at least 2s below what they are rated for then you will *probably* be fine.
    What are you using them to run? Weapon or drive? If you just mash the stick to full throttle instantly then it will pull a ridiculous amount of current which might cause it to explode too. So not good for a drive motor.
    R9000's Avatar
    Roboteer
    Weapon, hopefully a bar spinner. It'll be plenty geared down and have a timing belt for some slip since the motor itself runs at 780kv.
    what you planning Rory...... at FW large bar spinner by chance ?
    R9000's Avatar
    Roboteer
    That's for me to know and for you to see explode.
    solder some additional caps on the battery leads.
    R9000's Avatar
    Roboteer
    What size caps, and close to the ESC, or closer to the battery?
    are you planning to make a featherweight Tombstone ?
    As big as you can fit. Make sure the voltage is high enough on the caps for your battery otherwise they will go pop. Close to the speed end and I forget what the variable is called but you want them to react, charge and discharge, as quick as possible.
    You want low ESR caps like these: https://www.digikey.co.uk/products/e...s=UPW1J681MHD6
    I have a huge bag of them if you want me to send you some.
    They need to be as close to the esc battery input as possible for them to have much effect.
