Results 1 to 7 of 7
Thread: Motor and Wheel Question
Hybrid View
    I believe (if the team Danby website is to be trusted) that Foxic runs on 4 A28-150s. So they should work fine in a heavyweight.
    As for the wheels, I'd assume with the right wheel hub they could be used. I'm sure someone with more experience can give you a better answer on that one.
    Vantecs ain't wasted money, but it's a lot compared to other options. Those are about the oldest well proven ESC's around.
    4QD had several generations already.
    It's pretty low on the current handling side of things for a heavyweight. 20A continuous with peaks of 70A. That's closer to some featherweight ESC specs. I run Coyote on two 24V 800W scooter motors and use a Vantec 47E, which is 80A continuous and 220A peak, though that was down to getting a second hand one for a good price. If I was to buy brand new, I'd maybe look at something lower range.
    A Ragebridge controller would be a better and cheaper option compared to the 23F, at least for NPC drives. Can't comment on its use with Ampflows though.
