Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 190
Thread: 300A VESC in the works, feature suggestions wanted
Hybrid View
    Especially when you have 2 of these beasts cable tied to the escs... oops.
    https://www.digikey.co.uk/product-de...623-ND/5230581
    I have just about finished the pcb layout for my test power board, which I will just wire into the logic on one of the vescs I have laying around.
    2017-07-10 00_57_34-CircuitMaker (1.3) - PCB1.CMPcbDoc - 300A VESC.PrjPcb Euan Mutch is signed i.png2017-07-10 00_58_16-CircuitMaker (1.3) - PCB1.CMPcbDoc - 300A VESC.PrjPcb Euan Mutch is signed i.png2017-07-10 00_58_32-CircuitMaker (1.3) - PCB1.CMPcbDoc - 300A VESC.PrjPcb Euan Mutch is signed i.jpg
    I will be getting some copper lasercut to run the high current parts and put a bunch of caps on as well. It is currently 100x100mm so I can get it done at www.seeedstudio.com who have a cheap 4 layer option. So I will have 10 boards for £38.
    Will be putting in the order in the next few days so boards should arrive by the end of the month.
    This is all getting extraordinarily interesting... keeping an eye on this one!
    I have been thinking more about heat sinks the last few days.
    From what I know, the maximum time that these would be expected to run at for power is under 5 minutes. So since there is going to be very little airflow inside of bot it makes more sense to use the heat sink as thermal energy storage (ie a big block of metal). I have worked out that it would take 200g of Aluminium 5 minutes to go from 50 - 175oC when the heat dissipated is 80W from the driver. If you also factor in some convection it should be even longer. This would make it possible to make each driver board encased in an aluminium shell which would hopefully provide better protection in combat.
    You would just need to watch not to burn yourself on it after the fight lol.
    Maybe a dumb idea, but have you thought about heat pipes to help distribute the heat across your aluminium shell?
    Quote Originally Posted by overkill View Post
    I did think about that, the mosfets cover the entire surface area and *should* dissipate the same power each, so there shouldn't be any need for heat pipes. If the aluminium heat sink is very thick then heat transfer should not be a problem.
    If it was a bunch of very thin fins like in a graphics card then heat pipes would be a necessity. Currently I have two 150x200mm heat sinks for testing which I will sandwidch the power board between. Link
    Also going to get a Flir One http://www.flir.com/flirone/ so I can see what is getting hot.
    not sure how well heat pipes would help in this situation as they help more the moving of heat from A to B also it would add cost and weight
  8. #8
    I think I got my power dissipation calculations wrong. So I think it should run even better than expected. New numbers are
    16s
    15W @ 100A Max Power: 6720W
    32W @ 200A Max Power: 13440W
    65W @ 300A Max Power: 20160W
    128W @ 400A Max Power: 26880W
    270W @ 500A Max Power: 33600W
  9. #9
    What ambient temperature did you allow for in the calculations?
  10. #10
    These are pure heat dissipation so do not include ambient. If you have high ambient then it will be a bit worse, but that depends on the thermal resistance and capacitance of the cooling solution.
    Also these are for 100% duty cycle which is worst case scenario.
    Should handle 300a with 50oC ambient just fine.
