Page 12 of 19 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 190
Thread: 300A VESC in the works, feature suggestions wanted
Hybrid View
    New boards have arrived and been soldered up, testing to follow.
    I spent a lot of time testing over the last few weeks. It is now possible to run a motor using FOC.
    Sending a prototype unit to Rory Mangles to see what he thinks.
    Currently I have tested:
    100000+ ERPM - Seems fine, tested at 105000ERPM, will try testing with a higher Kv motor and see what the limit is.
    100A continuous - Seems fine, motor got too hot and started smelling. Will continue with larger motor in tank of water.
    Motor Tracking (Coasting motor) - Working up to 4000ERPM, working to fix at the moment.
    BLDC - Not working, probably related to motor tracking issue.
    FOC - Works fine, but detection does not work (Motor tracking). So you have to enter motor parameters manually from the detection.
    Still to test:
    PPM input
    150A continuous
    200A continuous (3min)
    High Enertia load
    CANBus
    Hall Sensors
    Encoder
    Once I get motor tracking working I will be gearing up for a first batch.
    I designed a new heatsink which can be waterjet, hopefully keeping the price down. The design allows multiple controllers to be stacked to allow them to share heatsinks. The plates are 10mm aluminium so you can just drill and tap holes wherever you like to mount them.
    Here is a video showing it running. (Excuse my brain fart on the ERPM graph)
    The heatsinks also arrived and look great, thanks again KCut! So have now tested at 190A (Max my powersupply can do) so far it manages to run for 25s before hitting the temperature limit and throttling down to 135A continuous. Although this is clearly because the thermal transfer between the board and heat sink is not good enough. So I have some better thermal pads on the way to try out.
    I also have some temperature sensors and hall sensors turning up soon to test out throttle on motor temperature and sensored mode.
    Started producing the first batch of 10 boards. Don't have enough FETs to populate them all but it at least gives us spares.
    That looks a piece of expensive kit.
    But I have use for it. Remind me, whats the max voltage of these monsters?
    Quote Originally Posted by maddox10 View Post
    Absolute max is 80v, max usable is probably around 70v (16s) to account for transients.
    Pity, as we have a 18S 60Ah pack for the motorbike.
    But for transients, isn't that the job of the capacitators and coils to smooth those out?
    Actually looking at the parts, I already was lined up to use 100V FETs, the gate drivers handle 120V boot, the linear regulators are 100v. So its just the current shunt amps that are limiting it (they say 90V maximum so they might work), which could probably be fixed by dividing the voltage inputs to them. I will add some resistors and solder jumpers to add that for higher voltage use.
  8. #8
    You might manage at 18s if you stick a load more bus caps on it, but it will be pretty marginal. If I remember right the simulation only showed 1-2V of ringing with 6 of those big caps. I can probably do a special for higher voltage with different FETs, drivers and shunt amplifiers if you really want it. Should be just a small layout change for the shunts. For robot combat 80V seemed a sensible max since robot wars rules have 75V maximum.
    What current is your motorbike estimated to use?
  9. #9
    We're to use a 18S 60Ah pack. This should be limited to 600A peak, but the motor we use shouldn't draw more than 200A in "insane" mode (a 250A fuse will be installed on the main powerline).
    Normal streetuse would be very mild with 70A , as that is the legal limit on the machine we're building.
  10. #10
