Results 1 to 7 of 7
Thread: Esc
    Team Gremlin
    Guest
    Hi guys, have any of you on here had any experience with the 4QD speed controllers?.. they seem cheap so are they any good or reliable ect? Cheers
    I have used VTX 75 24v ESC from 4QD in the past, but not used any of their new stuff. were very popular back in early robot wars.
    They were great then, and assume they are still.
    Edit - the VTX are now obsolete
    Thats the name i was trying to remember... they were popular in early robotwars before ROBOTEQ appeared.
    They will do a good job but they are not robot friendly - you need a radio control interface as well as a controller for each side (they will only control one motor each) which adds up to a lot of expense and complexity, as well as space - a dual channel Vantec or something more modern like a Wotty will occupy less space, be simpler, and give you more current capacity - they also use a full H-bridge rather than relays to change direction (which my 4QDs have) so will be slightly more responsive as well.
    wotty, roboteq or if you have the right setup, a ragebridge are all better modern equivalents. I'd not bother with 4qd or flog em on ebay if you have em.
