Results 1 to 1 of 1
Thread: Free Model Resource Thread
Threaded View
    R9000's Avatar
    Roboteer
    I've had people ask for some of the sketchup models I've made, and I'm going to post download links to them here, but I had the idea that maybe this thread could be just a general sharing thread for 3D models (of any kind) that people make for their robots, to allow those who prefer to do CAD to better plan their robots as a whole. So if anyone else wants to submit anything, just post a download link to your models and say what they are, and what format.
    Please bear in mind that my models aren't perfect. They're pretty close to the real thing since I measured the part and then made the model. But don't use them as a basis for any really precise machining or whatever, since the dimensions are only really correct to half a millimetre or so, and some little parts are missing (like the screw holes on the end of the drill gearbox).
    Antweight Stuff:
    The small brushed gearmotor that a lot of people use for antweights (the gears themselves are not modelled):
    https://www.dropbox.com/s/qv2wrlu4u3...arbox.skp?dl=0
    The Dys 2300kv outrunner brushless motor that I and some others use for antweight spinners:
    https://www.dropbox.com/s/o1js1fr3at...Motor.skp?dl=0
    The 3D-printed wheel that Rory Mangles packages with his NanoTwo V2 Antweight ESCs:
    https://www.dropbox.com/s/hvzxcx3jk3...Wheel.skp?dl=0
    The 3D-printed motor mount that comes with the NanoTwo V2 ESC:
    https://www.dropbox.com/s/hzbtj9v8iu...Mount.skp?dl=0
    A measurement box for you to put your finished antweight design inside to see if it fits. A 101.6mm cube with 'tinted' windows so you can see if any parts stick out:
    https://www.dropbox.com/s/27wmqllqns...20Box.skp?dl=0
    Beetleweight Stuff:
    1000RPM brushed gearmotor commonly used in beetles, note mass is not correct as the space inside the stator and gearbox are not modelled, just the external features:
    http://a360.co/2t7UzG3
    Featherweight Stuff:
    Drill motor with gearbox:
    https://www.dropbox.com/s/jlvzz3orw2...arbox.skp?dl=0
    A Turnigy HeliDrive SK3 600kv brushless outrunner - should be applicable to similar models too:
    https://www.dropbox.com/s/h38bukmvi8...Motor.skp?dl=0
    Just a simple cuboid that represents the Spektrum AR610 receiver that I have (and many other types), can be used as a size guide:
    https://www.dropbox.com/s/7yx9c73m4k...de%29.skp?dl=0
    Heavyweight Stuff:
    An Etek ME1004 I made in Fusion 360, from the given schematic drawings:
    http://a360.co/2p0Xtdg
