What are the rules on dimensions for beetle weights I can only see the weight limit listed in the rules and no mention of dimensions.
Rich
Rich
Rule is basically "Can you fit it in through the entry door?"
If the answer is no.... well the problem is obvious :P
Okay next stupid question without having been to an event yet how big is the entry door?
im not looking to build a massive beetle, what would some recommended dimensions be, I'm looking to make a 4wd beetle so want to make the most of the size
I think if you keep it below a meter itll be fine, however id need to double check if that applies to all arenas.
Theres a Facebook group for Beetleweight roboteers called "Beetleweight Robot Combat Discussion" - might be the best place to get a quick response
I was just going to ask this same question! I might have to do a bit of jiggering with my design in that case, it is about 380mm long at the moment (I think, don't have the drawing to hand).
It's come up in a few beetleweight threads, have you tried searching? A 20cm square would fit most beetles.
