Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 80
Thread: Build Log | Caractacus - Any Tips?
Hybrid View
    Quote Originally Posted by Roboteernat View Post
    Glad your recovering
    My axe is run from a 150w? scooter motor through a 2 stage chain gearbox giving 5:1 ratio, so not powerful, however it was rnning from a 30 amp electronize esc - as i didnt have a spare TZ85a esc.
    It was stalling allot during my time at ER 3 fights, and didnt suffer, nor did the ESC get warm.
    thats my insight into it if its any help.
    Thanks a lot for the reply! Was very helpful Just one quick question, did you wire it up the same as a drive motor (forward on the stick changes speed) or did you do like a servo type setup (stick position is the same as axe position)? (Hope that makes sense!)
    Thanks again
    EDIT: Just found your test video on you forum post lol it looks like you are doing the former xD but if you could confirm would be much appreciated!
    Last edited by willcaddy; 23rd August 2018 at 22:50. Reason: Found your test video lol
    I understand.
    I had no feedback from the motor position, so stick forward is drive motor forward, back, drive motor back.
    The only thing stoppuing it from going further was the chassis/floor.
    a video of it running is on the build log: http://www.fightingrobots.co.uk/thre...ld-of-fw/page8 first post on page 8.
    Im using a servo tester to control the motor ESC so i didnt have ti wire in the TX.
    EDIT: just seen your edit and that you found the vid
    Hello everyone!
    The robot is really coming along now and with loads of great advice from Roboteernat its finally nearing completion xD
    Just a few questions remain which i would love to get all of your input's on!
    Firstly I have read that Hardox 450/500 is the go to for a hard wearing axe head so I would like to use that but I just wanted to get your opinions on what design i should use? Is a hatchet style blade beneficial verses a pick axe style blade? I would have thought a smaller point would pierce better but I see a lot of robots going for a wider blade. Your thoughts?
    Also along that train of thought, Is there anything i should be aware off when using something like Fusion 360 to design the blade and export it for cutting? (also any recommendations on where to go to get it cut? xD)
    The other thing is I went with the BotBitz 85A ESCs and I found out from Roboteernat that the original ESC these are based off of has been discontinued. I hear the FeatherTwo's from Rory are pretty darn good so i was pondering switching the ESCs out for a FeatherTwo and using the one BotBitz to drive the axe motor.
    Again any thoughts/recommendations on that idea and other brands of ESC?
    I will post a link when i upload the latest video of what im doing too if you guys are interested
    Thanks in advance!
    Will
    about the Head styles, they each have benefits. a point delivers the energy to a single point allowing you to make holes in materials but will wear quicker than other styles. a bladed axe (like Terrorhurts) has a smaller point to deliver energy to and will wear better than a point but it will not make holes. A hammerhead will wear the best but will deliver the energy to the larger area. TBH design something that looks cool or fits the theme of the bot (for me a hammerhead)
    About Speed controller, a BB80 may be your best bet now as Rory has stopped making the single channel feathertwos, and getting a duel version to run the hammer is a waste.
    Quote Originally Posted by Maxamuslead View Post
    Sorry to be a pain! but do you have a link, I am struggling to find the controller you recommended
    Thanks again
    Hello everyone
    Unfortunately due to not being able to get a suitable speed controller in time I have decided to just make a push bot for the Cheltenham Extreme Robots to get a bit of experience and know what to expect for the next one. I do have some ridiculous ideas in mind though for decoration so watch this space xD
    Just a few questions about safety. Firstly, I know the robot must have an LED on show when its on but I'm curious to see what some of you guys have done for yours? It's running off a 6s LiPo so regular LEDs would just fry but I saw in a YouTube video that Angus (now part of Makers Muse) used a connector and plugged it onto the Spektrum receiver with a resistor in line. I'm not really sure if this is a good solution or if there is a simpler one out there?
    Secondly, Where abouts have you guys put your removable link? I know it needs to be able to be put in and pulled out with the robots top on (giggidy ), but I'm worried about it being pulled out mid battle. Having said that the loop on mine is rather long so is this just as simple as making it shorter? lol Would love your feedback Its going to be a fairly boxy robot because I plan on using the base and top panel again in the final axe robot so i was thinking of maybe putting it in the same place as Crabsolutely Clawful on the back wall of the robot?
    Again any suggestions is most welcome and thanks a lot!
    Will
  8. #8
  9. #9
    Quote Originally Posted by James Williams View Post
    Hey there Will. Regarding links, what I've done on both my FW's is bury the link connection a couple of inches deep within each & attach a cable tie to the loop on the link so it's much easier to pull out without risking the wire getting damaged.
    On Neophyte, I've also made a small HDPE flap held on with tape on one side so it can stick to the armour, but still be opened & closed easily by hand. Blacksmith hit the cap with it's axe during one fight, taking the cap off, but in the process saved the link itself (I wasn't using the cable tie method then).
    Regarding specific placement, I'd personally recommend placing it somewhere towards the middle or the back of the bot, making it as difficult as possible for an opponent to reach. I wouldn't worry too much about random knocks taking it out, as long as the connectors have a good grip you should be fine.
    Thank you for your advice The cable tie idea is a good one!
  10. #10
    Thank you for the advice xD i think i will have a play tonight
    And i was actually thinking of using the dual FeatherTwos for drive and switch out the BotBitz ones and re-purpose them for the axe. What do you think? I shall also look at the one you recommended thanks!
