Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: other alternatives to pneumatics
Hybrid View
    Have a look at the Tormenta 2 and Tormenta 3. They use a heavily geared down motor to act as a lifter to toss opponents out the ring. Tormenta 2 used a dewalt drill and gearbox combo while Tormenta 3 uses a more advanced brushless motor and a 64:1 off the shelf planetary gearbox.
    Tormenta 2 build thread - http://www.fightingrobots.co.uk/thre...d-diary/page25
    Tormenta 3 doesn't seem to have a build thread but there are some images of the internals floating around.
    - Probably not the best example, but here you can see how Tormenta does a flick as it drives at the wall to try and toss opponents out.
    Sewersnake/Stinger is the heavyweight machine that Tormenta 2 and 3 are based on, so look at their fights and there is also a video explaining what is inside Sewersnake. In effect its just a heavily geared down motor connected to a long arm/scoop.
    Quote Originally Posted by jamietoeg View Post
    Thanks for the reply. I had heavily reaserched tormenta 1 but hardly taken notice of tormenta 2. It's great to know that this idea is possible and that many have done it in the past. I'll hopefully try and take a look at some of these robots you mentioned as I think I previously seen some of sewer snake and the insides but didn't pay close attention to it. One question that I would like to ask is do you think that a cordless drill motor combined with some 6 MM chain would hold enough power to compete with some of the other flipper out there? And is it worth using 2 motors for increased power?
    best regards
    jamie
    I don't think a drill motor would make a flipper as much as a lifter. Two motors would definitely increase the power, but you'd have to connect them carefully so they don't run at different speeds or in different directions.
    There has been discussion recently of a spring-loaded weapon like Diotor's, that's wound back by a motor and released. Perhaps not the most reliable or easy to make, but neither are pneumatics.
    Electric axes are done in the past, with succes.
    With the right motor/gearratio combination an electric flipper is possible
    Maybe it's a crazy idea, but perhaps a flywheel-powered flipper could be a thing? You know, where you have an internal flywheel that's built up to speed with a brushless motor, and then you dump that energy into a flipper through some kind of clutch. It would also have a nice internal gyroscopic effect.
    Those are an absolute pig to make even for an experienced roboteer. There are only a handful of robots in the world that use that kind of system.
    Yeah I know the energy transfer would be quite a problem with so much acceleration, the clutch and any drive train would have to be rock-solid. Plus there's a spool-up time. Which robots use them?
