Hmm, I don't think I ever turned on Elevon mixing, but I think I have your solution. I believe it's because it's designed for mixing the elevons on an aircraft, so it tones the power down a bit.
You have to turn the trim adjust up from 100% to 125%, works fine now Thanks!
No problem, always happy to help!
Nothing.
Go to the endpoint settings and put aileron and elevator both on +125% and -125%
Hi all wondering if anyone can help me out, I've set mix 1 and 2 and it works but I've some how managed to get forward and reverse set up on the left and right of the stick and to turn left or right I have to move the stick up and down. I'm probably being a complete numpty but if anyone could help me out I would be very greatful.
switch out your esc's
Thanks, been a long day why I didn't try that I don't know.
Switched out the ESC's only thing it did was make it go forward pushing the stick left instead of right anymore help? Currently have it going forwards and backwards on moving stick left and right and turning on moving stick up and down.
mix 1 is aile - aile
mix 2 is elev - elve
trim active on both.
Pretty sure you need to do aile - elev and elev - aile, since you're basically mixing the action of one channel into another. Then work out your % values as needed to make the motors go the right way.
It's done! Kept my mix 1 and 2 the same and followed the instructions in the picture and it's worked a treat just need to work out now how to dile it down a bit as it's rapid lol
