There's nothing wrong with a Parallel port controller. My lathe uses a Parallel port. The mill uses both the Parallel port and a Smoothstepper Ethernet controller and the Plasma is USB.
Be careful with the USB controllers - I had endless problems with a cheap one from eBay and eventually bought a UC100 which is spot on. It turned out the eBay one was supplied with a hacked version of Mach3 - and wouldn't work with a 'proper' one. Unfortunately, the 'hacking' rendered bits of it useless, made the behavior unpredictable and the PC crash a lot! You may be more lucky - but for me it was a waste of money!
