Here you go - 22mm Silver Steel shaft - http://www.ebay.co.uk/itm/Metric-Sil...U2yjvQR_Hlb0-w
Funnily enough the silver steel that I linked is cheaper by a couple of pounds, but I'm glad you linked it either way, as I'm not sure what the price would be when I ask it to be delivered, so thank you very much Alex.
I'm also deciding to push the boat out a little and I'm going to ask for keyways to be made. (Shock, gasp, the horror, especially when I've talked down upon it...) But I don't know what a decent thickness for the key steel would be if I use the 22mm silver steel. Any suggestions?
DJ.
