Either side will do - I think its just a psychological thing to put the link on the positive side
Yes, disconect negative side last allows to 'discharge'?!
but yes could happen either positive or neg but your more likely going to have a connection made after your electronics than before, meaning you could blow us stuff unintentionally.
(your electronics are still live sided with the removable link on the negative side)
Did some rewiring, managed to use the housing for the fuse holder to make changing fuse easier.
I also made a second removable link with a shorter wire to neaten it and stop it sticking out so far from its insert slot.
Power light fitted and works (might change the colour), Wolf-E now complies fully with FRA regulations. Baring any faults Wolf-E is finished electronic wise. Did a full arming test, removable link works, power works, motors work, ESCs work, receiver works.
looking good
thanks
