Page 41 of 41 FirstFirst ... 31394041
Results 401 to 404 of 404
Thread: Team Coolspeedbot: first feather weight robot
  1. #401
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    1,005
    Looks like a neat lifter system, what is the MOD on the gears?
    As far as working to the limits, I try to think of it like this - if I don't test my robot at the extremes of its operation, it is more likely to break in the arena when I really need it to work. If something breaks now, it isn't as big of a deal because it is in a controlled environment and you'll know about it, either to adapt around that limitation or make it more reliable for when you really need it.
  2. #402
    Coolspeedbot's Avatar
    Roboteer
    Status
    Offline
    Name
    James Booth
    Robots
    Antweights: Killer-Wolf 2, Bunny-Ears. Featherweight: CSB 2 (in progress)
    Location
    Dover, Kent.
    Posts
    412
    Thanks, the gears are MOD 1.
    I think I need to reword what I mean by pushing it cause I'm going to give it some proper test like how much can it easily handle. But I'm more referring to still being in the mindset of being gentle with it, like treating it as the most fragile thing. It can handle it cause rewatching the test I've not tried to force the weapon to move more than it physically can do. i.e. keep the motor spinning after it's fully closed cause my mind keeps tricking me into thinking the gearbox bears are made of paper and will strip their teeth if the motor is spinning for a nanosecond after the weapon is fully open and closed.
  3. #403
    Roboteer
    Status
    Offline
    Name
    Jon-luke Buckley
    Robots
    Weapon of Choice (FW)
    Location
    Broadstairs, Kent
    Posts
    12
    Looking really awesome so far, it will be interesting to see how much it can lift/push.
  4. #404
    Roboteer
    Status
    Offline
    Name
    James Booth
    Robots
    Location
    Dover, Kent.
    Posts
    412
    Quote Originally Posted by TeamKnightshade View Post
    Thanks, should get a rough idea at some point when I give that a test.
