Progressing ever onward with the build of THRASH METAL; however I am currently stuck again with an issue.
How have people overcome the instantaneous braking issues that occur when using a momentum/kinetic weapon?
(By this I refer to the sudden stop that occurs upon some impact scenarios when in battle)
My current design is using an Ampflow DC brushed motor and a chain drive on a weapon that is roughly 21kg. I have done some rough workings for speed and acceleration but the braking and stopping still pose an issue. Currently my only solution that would work (and at that somewhat partially) is a cush mount system - similar to the rear drive and sprocket on a motorbike.
I have looked in to Bendix drive systems and centrifugal clutches but I cannot find a suitable method of protecting the motor armature and drive from damage when subject to immediate braking. Both methods do not give suitable mechanical solutions. Is there not a friction based clutch that has similar properties to a torque driver or the slip present in a drill motor?
Other factors include:
- I would prefer to not have to use a toothless belt as this would impede motor acceleration.
- I would also prefer not to use an AC inverter to power an induction AC motor as this is a weighty solution.
PLEASE HELP; I SEEM TO BE STUCK IN THIS VICIOUS CIRCLE OF A MECHANICAL QUANDARY - THIS IS THE PRIMARY ISSUE LIMITING THE FRAME BUILD!
And as always any help is much obliged![]()
