Results 1 to 8 of 8
Thread: esc's
    Hi all I have x2 esc's that are new I am unsure as to what to do with them at first. Do I need to programme them in or just plug and play.
    Anttazz's Avatar
    Member
    Status
    Offline
    Name
    Tony Smith
    Robots
    Rusty (HW) Cicatrix (FW) Rover (FW) Eggbeater (BW)
    Location
    Glasgow, Scotland
    Posts
    1,545
    That all depends on what they are and what you want to use them for?
    GoolRC 320A 6-12V Brushed ESC Speed Controller w/ 2A BEC of eBay. And they are just for forward and reverse control on the wheels
    Anttazz's Avatar
    Member
    Status
    Offline
    Name
    Tony Smith
    Robots
    Location
    Glasgow, Scotland
    Posts
    1,545
    Shouldn't need modified then. I don't see them being up to much though, the rating are exaggerated to say the least but hopefully they work for what you want them for
    Oh, the blue ones. Forget it if for a featherweight.
    They are great smokebombs if you do anything over 8V with a batterydrill motor.
    Reverse is not full power either making building a drive with them "special".
    leorcc's Avatar
    Member
    Status
    Offline
    Location
    Hoogvliet, The Netherlands
    Posts
    3,320
    First thing you need to do is take off that Tamiya plug for the battery. A so called 320A ESC with a Tamiya plug, Chinese will just print anything on the box as long as it sells.
    I believe the 320A comes from the sum of the FET ratings. So either 4 80A fets or 8 40A. But that doesn't really matter because the crappy wires and thin traces will probably melt first. The pair I bought didn't even go between forward and reverse without a 1 second delay.
  8. #8
    So basically these was not a good buy haha hopefully get some use out of them even if it's just to gets use to the 'feel' of the robot
