Results 1 to 2 of 2
Thread: robot building partner needed
    Assuming from your name being a year, putting everything in bold and the general way you write - im going to assume your 13 years old.
    Thusly its best you be told that Heavyweight building is extremely dangerous and should only be undertaken under supervision by competent adults. Skills such as welding and grinding are likely to be required, which are potentially lethal and can easily lead to you losing extremities.
    Additionally to that, heavyweights are very expensive and require alot of space. Your likely going to be spending at least £2000-£3000, and even then would require facilities to move the robot about.
    You need to actually research what your getting into, being ignorant will get you seriously injured. Thusly, the best advice is to start small to learn the skills with a featherweight or beetleweight.
