Hi Mario, What model Movimotor are you referring to and how much does it typically cost?
I didn't know that! that's almost half a kilo heavier per motor then the bosch 750!
On par with the Iskra's. Those motors use a solid 5mm wall steel tube as motorhousing with ali endcaps.
No taping off the vent holes and so on.
No Idea and no Idea. It's a 24V version with around the power of a Bosch 750.
dc electric motor series s114se
I do like the 24v 800w iskras. 2.5kg, solid with no holes to speak of and terminals to hook up to. Smaller than a bosch 750. Shame they are over £200 new.
Ellis components are selling the 750w Movimotor as a Bosch replacement for about 95 quid. Looks like quite a strong unit with the exception of the Cast end caps. Shouldn't be to much of a problem though as long as the motor body is well secured to the chassis.
Have you attempted to run them at 50v Mario?
I didn't run them at all. I just handled them a bit.
And, no, it isn't a good idea to run them at 50V. That's double the rated voltage. It's been a rule of tumb since the start of RW that overvolting more than 1.5x will result in broken motors.
