Those motors do not look secure at the end of those thin supports. Can you not bring the motor closer to those side plates and reuse the width of the whole drive? Its a bit of work but will mean the shell would fit.
It appears my guesstimation on the weight was out... Slightly haha..
Anyone fancy a guess?!
If you used 3.2mm Hardox 450, and my guestimate of the size is correct, it's 35 kg for the shell alone, at least.
With the box section you did show as internal bracing, it's 45 kg , without anything in there.
Just a guestimate on size. You're building large.
On esc. I think you can download everything from the Roboteq site.
This looks amazing!!!! Great work!
So i got this through today from active-robots, no instructions, no cd? or extras cable as all offerd by RoboteQ official site..
Im still not 100% on speed controllers, so do i need the cd and extra cables for the 2 Bosch motors?
download manual
they are quite easy to use if you need any help I might be able to talk you thought it or pop by if needed
pm if you need any extra help
No worries, as for cables for the Bosch motors?
I got mine today too. The motor cables are there already, you need the cable to connect the controller to the RC. You need to buy that separately from active robots.
