Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: [FW] Hydraulic Crusher Bot
Hybrid View
    Me and a work buddy, Dave, are working together on a featherweight for the champs in April. We're going to post our progress here, will probably just be working on spare weekends up until the event.
    Here is a very rough idea of the kind of design we are aiming for. Nothing is set in stone yet, just trying to think of a shape that works, and this is our best effort so far:
    We're going to be running two
    Satern-16's with 775's from Ranglebox with a belt driven 4WD setup. Powered these things on for the first time on Saturday and they are absolute beasts! Can't wait to get something driving around on them.
    For the weapon, we're using a hydraulic pump from a convertible car roof. This pump is nice and compact, with the motor, pump and reservoir all combined into one block. Spent the weekend figuring out which valves and wires do what, it works in a strange fashion, with different flow directions controlling different outlets. It works a treat though, one ram had no trouble lifting a fully grown man off the ground, and we plan on using two of them
    We used a pretty ghetto set up for testing... a computer power supply with all the wires soldered together and croc clipped onto the motors!
    That is all for now... more soon!
    What car is the pump/motor combo from? Looks good btw
    Quote Originally Posted by Giles View Post
    It's out of a Mitsubishi Colt, not sure which exact model as we just got it from Ebay. Weighs 2.5kg in total for the motor, pump and res. Good bit of kit!
    Those pumps, using a quick google search, are good for 1750 PSI max.
    http://www.jagrepair.com/HydSystemEvaluationXK8XKR.htm
    Should look into that.
    Still 120 bar tough. A 32mm bore ram will develope 1 ton of force on that pressure.
    The main question, how much oil is in that tank?
    Crusher norm for feathers. No clue
    Ram power ain't the main thing. Pressure on the tip is what counts, combined with the shape of the tip.
    Also, stroke and speed have their place.
    The 20mm rams, what stroke are those? If the stroke is longer than 40, the forces impared in robot combat will bend the rods.
    On the other hand, Tiberius uses a 70*148 ram, with a 20mm hardened steel rod, and it seems it's still going strong, even build by me in 2003.
