Results 1 to 7 of 7
Thread: Team Psyclone's Farewell Sale
Threaded View
    Hey guys, I've been off this for a while, and I believe this will be my final time back, as I no longer have the money to continue the sport. It's very unfortunate, but you can still benefit, as I have a few bits and bobs to sell, mostly ant stuff, but oh well.
    DISCLAIMER:As of now I don't actually have the photos of most of this stuff, but I will by the end of today. If you don't know what something is, I'm afraid you'll have to Google it.
    So, first up is a E-Flite Blade 2.4ghz Transmitter! It's completely in working order and undamaged, and is pretty good for an ant or beetle. PRICE: £15
    DISCLAIMER EDIT OF IMPORTANCE: It turns out it's not actually an actual E-Flite Blade, but a very similar (And working) clone. It runs on the DSM2 frequency so it's compatible with OrangeRXs. As an added bonus over the Blade, two triggers at the back make it produce "Shooty gun noises" )
    Second of all, I have a pair of those micro metal gear motors, not sure on the ratio, but I'm sure they're the medium power ones. They were bought direct from Pololu with a pair of 32x7mm wheels. Both motors are in working order, may need leads re-soldering though. PRICE: SOLD
    Next on the list is a fairly similar size item, a Sabretooth 2x5. It's not massively old, and it still works completely. I don't have a box for it however I can cut a hole in some foam I have and make a box PRICE: SOLD
    Almost there, the next item is a large sheet of 15mm thick black HDPE, which goes hand in hand with the next item. It was originally 1m by 0.5m, but has had some cuts off of one of the corners, less than 1/8 of the sheet however PRICE: £25
    Now, my last and best item of this sale (Although I may add more if I find it, can't remember anything else off the top of my head) is my most prized robot possession, my heavyweight chassis. Formerly known under the aliases "GMAN" and "Metanoia", this shell is very much like Leveller II. It does not come with all the panels, but they'd be very easy and cheap to replace.
    The panels that need replacing are the angled face panels next to the flipper, and the lower back panel.
    It has no internals, as I never got round to buying any. It does, however, come with two 4QD main boards, which I'm told do work, and are safely bubblewrapped up. As I say, I never got to use them, but I'm confident they still work, as the board doesn't even look scratched or damaged. It does NOT come with the RC interface board, however, so you will need to buy this yourself. It also comes with a pair of wheelchair wheels, and two packs of M6 bolts which are the correct size to hold the panels on. PRICE: Open to (Sensible) offers, I'll converse with you over PM, Do not post offers here!
    This item will have to be collection only, but I would prefer to have the money paid through paypal, but if that's completely impossible, then cash on collection can be arranged. The robot is about 1m long by 0.8m wide and 0.5m tall.
    Thank you for looking, it's a shame to go but it must happen.
