Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: ESC/Battery/Motor help!
    Just ordered a pair of these 1200 RPM motors from ebay:
    http://www.ebay.co.uk/itm/12V-DC-120...item3f48c18cf9
    I'm trying to figure out what ESC/Battery would go well with these motors. I'm pretty new to this stuff, I understand how the ESC needs to allow for more amps than the motor will draw, But I'm not sure how to calculate how much amperage these motors will draw to begin with! I've looked up some values, but to no avail.
    What ESC and battery setup is typical with these kind of motors? Or better yet, how do I effectively figure out which components match which? From what I've read, there are some ESC's that are also "forward only" which should be avoided too?
    One ESC I did find that I thought might fit the bill is this:
    http://www.hobbyking.com/hobbyking/s...d_Car_ESC.html
    But 45A seems a bit overkill to me? Correct me if im wrong there. Im also looking to keep the costs of my components down to a minimum, as this is my first bot and I think I will make a lot of mistakes/learn alot during this process.
    Sorry if this has been asked a thousand times. I couldn't find the right info I was looking for via searching!
    Hi Giles, the 10a Botbitz ESCs on my site are the norm for driving 25mm gearmotors like the ones you have ordered. They're behind the majority of UK beetles.
    For battery, depending on the type of robot, you'll likely want somewhere between 500mah-1300mah and 3s (12v), assuming LiPo. My spinner runs 1300mah, but a 2WD robot with a servo powered lifter weapon (for example) could get away with much less.
    edit: am I forever-more destined to get post-ninjad on your threads? :P
    Hi! I'm a bit of a scrounger so can give you my highly low budget suggestions.
    Buy two of these
    http://ranglebox.com/product/botbitz-10a-brushed-esc/
    and one of these batteries
    http://www.componentshop.co.uk/12v-2...tery-pack.html
    and one of these chargers
    http://www.componentshop.co.uk/intel...ace-packs.html
    Job done for fifty quid This is all basic old tech stuff but I use it because it's so cheap and easy to get hold of. You can get posh ESC's, lipo batteries, lipo chargers and all of that carry on but you will hit a hundred quid very very quickly. I have a build thread with all my naff cheap robots on made from biscuit tins, plywood and chopping board that you might find helpful lol. Can also give you some links for bolt on wheel packages cheap if you need it. I'm mostly into beetle and ant weights so can help a bit.
    As long as the weapon isn't too big that motor will spin it just fine. It is on the slightly small side, so perhaps try and leave room for a 2830 NTM or similar and perhaps a 30a ESC down the line. Will certainly get you spinning, though.
    If you're familiar with LiPo (seems likely as you're into RC) I'd suggest a 1000mah or so 3s pack. Something like this: http://www.hobbyking.com/hobbyking/s...arehouse_.html. It's currently all of a fiver, on sale.
