Yes please sam!!
Yes please sam!!
Quick question, when building a chassis out of hdpe, should I use threaded inserts on all joins? Including inner bulkheads and floor, or do some people use wood screws in places. To go into a full combat event
Neither ideally. The screws will wear down over time and the threaded inserts pull out. Barrel nuts and bolts are the way to go for HDPE.
Ok thanks for advice
For places where barrel nuts won't fit, you can use Tee nuts:
They are a type of nut insert that is pressed in from the far side of the HDPE and will not pull out. I have used them for years without problems.
ooooohhhh I forgot about these! :-)
I'm stuck with mounting a small titanium scoop/lip to front of robot, I'm mounting it too hdpe, any ideas what would be the best option for full combat
Lots and lots of screws with a nylock nut and a wide fender washer on the back. If the titanium is thick enough, use countersunk screws; vertical spinners love to bite the heads off screws.
Ok thanks I was using 5 mm. It's to get the front to give zero ground clearance
For 5mm thick material you can use at least an M6 countersink screw. Depending on how thick the HDPE is you could use those Tee nuts I mentioned earlier to save space.
