You can use the BotBitz TZ85's, those are 6S rated.
If you feed the 18V motors 24V they can run hot, or even destroy themselfs.
But you can set the RX/TX that the esc's don't feed full power to the motor
Ahh ok so what battery would you suggest using ??
ive be looked at the TZ85A Before but I can only find them in brushless whilst I need them in brushed![]()
