Results 1 to 4 of 4
Thread: Steel discs
    I'm looking for some steel discs to buy,
    They are weights for a project I hope to start.
    Ideal size 120mm diameter 10mm thick.
    the size can be 50% in either direction as I can make the thing to fit the discs.
    Ideally about 10 off or more, material steel.
    They can have a lead in on them, and don't have to have a pilot bore, tolerance is not an issue as I can adjust the weight.
    I am ideally looking for scrap, where a process has plasma cut some holes in a plate for something and the discs are scrap.
    Thanks for your help
    In the related items of that ebay listing^
    http://www.ebay.co.uk/itm/Qty-1-6-0-...83952285&rt=nc
    6" and 6mm thick weighs about the same as 10mm thick and 120mm diameter. Lots cheaper.
    ^that works lol
    also
    http://www.lasermaster.co.uk/easy-order bout 60 pound ex vat to cut them out if you need it.
