Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 135
Thread: Team Shakesc : Build Diary
  1. #101
    What motor are you planning to use with the BB220? I found that the rear plate on the older P80 gearbox was hard to use for anything other than the CIM motor and ended up making my own replacement.
  2. #102
  3. #103
  4. #104
  5. #105
    R9000's Avatar
    Roboteer
    Is this robot going to be the new Tornado/Storm 2? Those look absolutely vicious for drive motors.
  6. #106
  7. #107
    R9000's Avatar
    Roboteer
    Nice! I'm quietly trying to make the move over to brushless too. Bought some for my next featherweight and I'm looking into heavyweight weapon drives - if Ellis with Pulsar, and the Big Nipper team can get them working well, then hopefully so can I.
    I do like the Battlebots style, it feels like a fresh approach with a lot of diversity. Admittedly a lot of BB teams have much more funding than us, but I definitely feel there's a place in Robot Wars for lighter-armoured, fast aggressive machines, as we've seen recently to some extent. All the best with your brushless endeavours!
  8. #108
    That custom shaft looks excellent! If you are planning to run the motor at its full 53V rating, you need a 300A ESC to cope with the motor's 15KW peak rating and there are very few choices. I have no idea if its possible, but simon K firmware on the Hobbyking Fatboy2 ESC would be a cheapish option.
  9. #109
  10. #110
    Fliers should be SimonK compatible. Just need the right flavour of code. Go for the 400a ones at least - they have the same fets as what even hobbyking calls a 250a (dlux) esc.
