Results 1 to 2 of 2
Thread: A few bits and bobs
    Nothing exciting really, just came across a few things when I was tidying out the workshop after the champs.
    L-R: Standard 600g FW-sized CO2 bottle; 3mm stainless steel tube with ring tooth attached; FP pneumatic ram, 25mm bore x 50mm stroke I think; 6mm ali tube 150mm long x 90mm diameter; CO2 regulator.
    The CO2 bottle is missing the handle to open/close it. The valve seized up and won't open, and it got chewed up a bit as I tried an assortment of tools on it to open it but with no luck. The valve, however, unscrews so if you can find a replacement one, it should be easy enough to use the bottle again:
    As these aren't really top-of-the-line components, I'm just going to list the postage costs (and component weights) and any interested parties can submit their offers on top of those. Anything not accounted for by the end of the weekend will be getting chucked.
    P&P costs​
    CO2 bottle (1kg) - £6
    Regulator (1.2kg) - £6
    Ram (2.1kg) - £8
    Ali tube (0.66kg) - £4
    Steel tube w/tooth (0.8kg) - £4
    Any questions, fire away.
    Ta
    80% of stuff accounted for, but all pending payment. Just a heads-up that this will be my last weekend at home for a fair few weeks so if any of you want stuff before the end of June, I'll need to have payments and postal addresses confirmed by tomorrow afternoon. Ta
