Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
Thread: Tashic's Robots
Hybrid View
    On HDPE, I can supply the stuff easely enough. But P&P is an additional cost from Belgium. PM me about sizes and cost.
    A full steel baseplate is heavy. Thinner than 2mm is just waiting to be crumbled like a tin can.
    Best case is to use 3.2mm Hardox, still the weight of steel, but way stronger.
    A sheet of 200*200*3.2mm weights 1 kg. An avarage feather is 300*400mm, resulting in 3 kg baseplate.
    Did some testing these last few days, by making this platform:
    the motor holders are made out of 3mm steel, if it turns out to be too heavy, I might make them out of HDPE.
    The wheels are made using slices of go-kart tyres which I screwed them to the wheels:
    The go-kart rubber is very grippy! When I try to push the robot, the wheels don't slide but they turn the motors.
    The problem is that leaving them this wide, the wheels aren't perfectly round, but they flex with the weight.
    Also the scooter motor had arrived, and I will do some tests on that later.
    Updates:
    Started the build by getting the base and making the axe mechanism:
    Right now it weights 8,5kg including the axe, the gear ratio for it is 5:1, having on the handle 55 teeth and on the motor 11.
    The base is 2,5mm steel and the dimentions are 315mm X 370mm not counting the slots for the wheels.
    This is what (hopefully) it's going to look:
    I decided to make a lower body (kind of looks like K2 now), to save weight, and the scooter motor is closer to the center:
    I will think of a cover for it later.
    So, some time ago I found a place to get the HDPE from italy, and 2 days ago I ordered some sheets.
    I thought that the parcel would arrive next week, but after school I found them in the living room:
    Wow they look chunkier than I thought!!
    They are two 20mm black sheets and two 10mm white (they only sell the 20mm sheets in black).
    I only really need one of each but I wanted some more to use them when needed.
    So hopefully I will make some progress these days.
    One more thing, what insert do you use and how you "insert" them in the HDPE?
    Edit:
    Little bit of progress, I made the supports for the axe out of wood, after I made some modifications to the very cheap jigsaw:
    I also need to shorten the chain, like a lot! Which means some spares.
    Also about the inserts, are these good?:
    Or I need ones without the lip?
  8. #8
  9. #9
  10. #10
    Yeah you probably want a bit more on that. Maybe try for 20mm if you can manage it? I don't own an axe bot myself but I seem to recall Hatchet's shaft being 15-20mm...
