I thought my robot was still a bit big!
Yes it does fit in the bottom, I noticed at the NEC that it would be good to have a one stop wheelie toolbox. The hardox jackets are made there are pictures further back in the thread.
So today has mostly been trial and error finding space for everything, I think progress is being made. The robot is 370mm in width and so its tricky to fit all the components in.
looks sweet Gabe- if your tight on space you could change the fittings coming out of the trev reg down to 6mm OD pipe?- would do away with all those elbows etc and you wont notice any difference in flow id expect... its only between buffer /valve / ram you need big pipe
Thanks Bud, I was thinking along those lines, are you saying I could bend the 6mm OD pipe and dispense with elbow fittings?
spent the evening re -working the plumbing, 6mm fittings ordered.
That's seriously impressive in the space and how close to the original it is.
Thank you Dave, no special skills, just time and a lot of measuring. I've got loads of pictures of the 'Original' scale is roughly half. but I cut its Butt down by about 5 cm to save weight. It will of course have a different livery.
You should get in touch with George Francis and see if he will let you copy his livery and call it mini chaos or something lol.
