Results 1 to 9 of 9
Thread: Spinner Brushless motor help
    I`m looking at powering a spinning disc with a brushless motor but I`m new to brushless.
    I want a low profile one to fit under the disc and have seen this
    http://www.hobbyking.co.uk/hobbyking...Outrunner.html
    But what is the difference between multi-rotor and one like this?...
    http://www.hobbyking.co.uk/hobbyking...ner_Motor.html
    I want to aim for around 30A maximum and 11.1v
    (The above are for examples, not necessarily what I`ve chosen)
    Belt drive so reduction
    Thanks, just looking on hobbyking now...
    Gone for a Turnigy D3530/14 1100KV Brushless Outrunner
    https://www.hobbyking.com/hobbyking/...dProduct=35192
    and a 40A ESC
    https://www.hobbyking.com/hobbyking/...dProduct=36846
    When I start building it I`ll set up a diary thread.
    I expect that to pull around 250w on 3s. That sounds comparatively low to other beetles but I'm confident others are often way overpowered. It will be interesting to see how it does, as the class grows in the UK what will and won't work will become more obvious. When put into proportion with feather weapon motors from a few years ago, 250w should be buckets for a beetle.
    With that speedo you have masses of room for an upgrade anyway.
    Look forward to the build thread! I can't wait to get stuck into beetles again.
    Yes an upgrade will most likely happen anyway, my approach is always get the thing working first then see what you can push it to :-)
    You're wiser than I'll ever be! :P
