Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Sprocket
Hybrid View
    Grind or file a flat onto the shaft for the grub to engage in and secure with some loctite.
    Thanks for the advice Gary
    No bother. Just realized I should have said thread lock to secure the grub in place.
    If you have the time and the patience then you can use a set of needle files and a regular file and make a keyway and flat and press a key in the gap.
    I'll give that a go, what size screw would be best? I can get up to m8 from technobots
