Quote Originally Posted by overkill View Post
No Problems, I need a bit of a break from robots today. Do you prefer to control the motor with relays or with electronics. The main differences are that the relays will be a bit cheaper but will need more custom wiring. Using a solidstate H bridge might be a bit more compact as it can fit right on the arduino board
This is a break? haha
Correct me if I'm wrong anywhere here!
Thats 2 options then:
1. Relays using physical contact as feedback as such? Seems fairly simple to set the limits of movements/set points
2. H bridge, how are the limits of movement set? and the set points, this is where my total lack of knowledge towards electronics is blatantly obvious!
But in both cases i need:
1. DC to DC power supply
2.
Arduino
Any ideas of a very vague cost to get this system up and going? Projects cost about €300 so far
