Not much; the main items will be a couple of relays (or a single DPDT relay) and a simple circuit to drive them as an MCU output doesn't have the capacity to drive a relay directly. Alternatively, you can use an 'H bridge' which essentially does the same job as the relays but its all electronic with no moving parts. You will also need a DC to DC power supply to drop the car's 12 volts down to 5V or 3.3V for the MCU. almost all that stuff is "off the shelf", I or the other furum members can probably whip up a circuit and a shopping list if you need it.
