Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Magnets, how do they work?
Hybrid View
    Sorry, couldn't resist the reference.
    Been looking at magnets for HardWired II to make a relatively flipper-proof configuration (idea is to make it so 'heavy' that flippers can't lift it), which sorts of magnets are best for the job?
    I found these, http://e-magnetsuk.com/magnet_produc..._mounting.aspx (The E1021 ones, 50kg pull) and wasn't sure how suitable they'd be to say, bolt on the underside of the machine. The plan was to have four, one on each corner if the weight allows for it. Alternatively, I did spot this one http://www.first4magnets.com/circula...0kg-pull-p3497 which a bit bigger and presumably heavier with twice the pull of the others I saw. Also quite a lot more expensive.
    Would either of these be suitable at all, and if so, which one would be the better choice?
    Thanks in advance!
    Just to say, Hannibalito 3, not the most powerfull or efficient flipper around can lift around 400 kg on the tip of the flipper.
    Hannibalito 4, can't do as much, because the arm would buckle, but in theory, that one can lift 2 tons over 50mm with the ram alone.
    If you add that much weight with magnets, your drives will have an issue with that. Or if the axles or chassis bend and ground you
    The problem with magnetic hold-down is that the magnets have to be really close to the floor to have much effect. That stated hold-down force of 50Kg will be when the magnet is attached to a steel surface. Magnetic attraction decreases with the cube of the distance so you will get far less attraction when the magnets have a reasonable floor clearance of (say) 5mm.
    The other problems are getting high-sided by an uneven floor - it would be really embarrassing to get your bot stuck to the floor. You will also sweep up every magnetic item on the floor and this could also high-side the bot if you pick up something large.
    Japanese sumo bots use magnetic hold-down very successfully but their arenas are super flat and kept clean.
    Rather than a permanent magnet I'd use an electromagnet or something which can be switched off, otherwise moving the robot might be a problem...but as Mario and Nick said, there are a whole lot of other factors against their use.
    Below I linked two magnets which look like they got the power to hold to the ground, but I got no idea of their own weight and power requirements to make them work...add to that a hefty price tag!
    http://www.ebay.co.uk/itm/1100-LB-Ho...item27dbf396f0
    http://www.ebay.co.uk/itm/2000kg-440...item27d8e7dbde
    Last edited by Liftoff; 5th February 2014 at 07:55. Reason: PS. the last linked magnet wouldn't even fit a HW...it weighs 125kg!
    I recall seeing one of those door electromagnets at a place I worked; the cable to it was quite thin, so the current requirement can not have been much.
    On the magnet thing I do like the idea of a rolling magnet idea, the magnet being round will always contact the arena floor for maximum attraction. then use normal wheels for drive. there are lots of problems with this idea like how to turn the robot or what happens if the magnet picks up some steel like loose nuts or washers. but there are ways to mitigate this.
    The pushing power is down to the friction between the tyres and the arena floor. by increasing the attraction between the floor and the tyres the pushing power will increase, but also the drive transmission load will be greater!
    I say give it a go! Invent something new and refine the idea.
    There is nothing wrong with using magnets, at least in theory, to make a robot seemingly heavier. But in the arena, a rambot with a shallow wedge knocking into your machine at 15mph will very likely unstick it, as will a flipper. I imagine most FP flippers could lift a robot "weighing" 80kg quite easily anyway, as Mario says.
    The main issue I see is the strain on your own robot, if you go for serious downforce. From a mechanical point of view, your robot's drivetrain and chassis has to be strong and stiff enough to prevent buckling under the forces, which is entirely possible (Grant's new axe feather will have around 100kg in downforce, note it doesn't actually have any tyres, just aluminium!), but will take some good design and construction. From an electrical standpoint, the strain is even greater, the drive motors will have to work much harder (effectively you're driving a heavyweight with featherweight kit), which will at very least shorten their lifespan if not burn them out on first testing. Because the motors are working so hard, you speedos will have to be able to handle the current draw, and your battery beefy enough to supply it. Of course all wiring would have to be able to move this current around too.
    Point being it's not quite as simple as popping a few magnets under your bot and thus becoming flipper-proof.
    Having a little in the way of downforce to give you the edge in grip over the opponent is viable, though. Even just a few kg of pull will be within the range of the average feather drive and will give you a serious advantage over other machines.
    edit: oops, I wrote short story, sorry!
    I see, I might rethink that plan then. Had no idea flippers were that powerful for one, and it sounds like the downsides of using enough magnets to retrieve satellites from orbit probably outweigh any benefit they may bring, at this level of engineering on my part anyway.
    Would it be better to, say, go with much lower levels of downforce over each wheel to help improve grip, or just going for better wheels to get that improvement? All I'm thinking is that my machine, at the moment anyway, is heavily focussed on pushing other robots about, and whilst 4 drills will be able to manage that, I'd not stand a chance up against say, Satanix's beefy drivetrain, or most of the others using the tougher motors... I was debating detachable side skirts like Storm II as well (albeit at the risk of looking suspiciously too similar to it) for when I come up against flippers, but it's the worry of them getting caught between floor panels...
    4 drills will out push any robot of any drivetrain if it gets underneath. So, good grip is one thing, but unless you can wedge under another bot to make use of it, it's pointless. Focusing on design is probably best for now.
    Enough downforce to make a difference is easily enough added later on; they don't weigh that much when you're only trying to get (gap between steel floor and magnet allowed for) 3-4kg pull.
    Tormenta 2 is just 4 drills, 24:1 gearboxes and 100mm wheels, and whilst it's not particularly powerful, it gets underneath and shoves other machines around nicely.
    Using magnets for extra grip is very plausible if its done right. Ellis is only partly right about magnetic hold-down adding strain the the drive train; there will certainly be extra force on the gearbox bearings and adding outside axle bearings is always a good idea, magnetic hold-down or not. While the bot is driving in a straight line the only extra stress on the drive train is the extra rolling resistance of the wheels, which will not be much. Magnetic hold-down is not like adding extra weight to the bot as the bot's inertia stays the same and the effort needed to accelerate it will also be the same.
    The extra strain comes when a 4 wheeled bot tries to turn with skid steering; the wheels won't break traction so easily and the motors will draw more current. This wouldn't apply to a two wheeled bot as its not skid steering. All bot designs would use more current in a pushing match as the wheels have more grip and need more current to break traction.
    IMHO, adding around 5 to 10 Kg of magnetic hold down to a two wheeled bot would give it really useful traction while not increasing the current draw and drivetrain stress too much. The NIB magnets needed for that probably wouldn't be too large or expensive either; well worth some experimentation!
