Im in need of 2 steel rounds only about 4mm thick, 75mm dia and 20mm bore with 4 holes at 90 degrees from eachother for attaching wheels to axles
If anyone can either make some up for point me to somewhere I can it would be appreciated
Mobility Scooter Hubs
The dia is too large to leave them whole and would be very difficult to cut them down properly so would rather get something fit for purpose
http://www.ebay.co.uk/itm/Mild-Steel...item46165cbad2
they might even be able to put the holes in for you
They look good but the seller is unable to be contacted about the alterations I would need hahaha
buy some 4mm mild steel plate and make them. Hacksaw, bench vice and a decent file along with a hole saw and some drill bits and it's very doable with patience.
