Page 28 of 58 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 576
Thread: HardWired II
  1. #271
  2. #272
    I'm agreed with Haz, Sketchup is easy to use and gives a good way to plan both the interior and exterior of a robot. Me and Ellis have put some models up on the workshop, I've recently done the Scorpion XXL, GR01 and Banebots 775s. As for an example of how it can be used:
  3. #273
    Nooby sketchup question time, which template do people start with and where's the workshop
  4. #274
  5. #275
    Quote Originally Posted by overkill View Post
    What's the plan for when it gets flipped? Are the wheels going to be large enough for it to drive inverted or will there be some self-righting mechanism? I'm not sure that thick HDPE over 6mm Hardox is effective; just using thicker Hardox is likely to be better.
    Most likely going to have chunky wheels that stick above the top on the back, but that'll probably only be the back two if the design runs how I'm thinking it might. Rather hoping that the disc would have enough power to knock it back over if it pivots on the back wheels but that's a pretty huge ask...
    Probably just going to be 3.2 frame, with layered HDPE bolted onto that - 6.4mm on HardWired II worked fine, but for a slightly larger machine with a 1.5-2kg disc on the front (what I'm aiming for, at least) it doesn't leave me a whole lot of room weight-wise. Also, I can replace HDPE, probably have a rough time bending 6mm Hardox back into shape with only the most basic of tools...
    Comments noted, returning to sketchup when I've got a spare minute to start again on the refurbished design of it. I won't lie, I have no idea what I'm doing and this model was literally just a 'this is the sort of thing I'm going for' to work upon - keeping the design similar though, just with improvements - I like the stealth bomber type shape! Will be using plenty of provisional parts too, the brushless drive research that's ongoing means things might change, but for now I'll be using 42mm NTMs with those Gen 1 turnigy trackstar ESCs. I can't design them for the life of me, so the ESC will just be a box labelled ESC with the right dimensions...
  6. #276
    Given up on Sketchup, I can't do it for toffee. And all my attempts end up looking like a slightly wider and shorter Rango or K2 for some reason... Not that there's anything wrong with that but I don't want to look like I'm nicking designs! Back to pen and paper, I think!
    In other news, just taken HardWired apart fully for the first time since the champs, actually loads more issues than I first thought. First thing is that the damage caused by that hit from 720 was more than just cosmetic, it's actually bent the wheel in slightly, so the gear was grinding a fair bit when I gave it a little test run direct from a battery (can't figure out the problem with my TZ85...) that needs looking at, and a little bit of cleanup on the wheel holes because they're catching very slightly.
    The top supports have bent too, but that should be resolved with the new lid being welded on, and made of Hardox (come at me, axes) as well as the baseplate having a little bit of damage. The main shell (bar a slight bend from NST/720 and gouge from the front courtesy of Ironside) is pretty much undamaged, discounting the scratches. Very impressed, the HDPE panels on the side will take most of the shocks out for next year, so it'll be practically indestructible. Playing around with the idea of a shock mounted 6mm hardox front panel on the scoop (it's just that one panel with HWII on there, not the entire front) to give something hard for spinners to hit and fly off into the distance, but not causing any shock damage to myself, but it's still up in the air.
    Next job now is finding out why this TZ85 isn't working, need to get the heatsink off and have a look at the circuitry and see if something's come loose. Oh, and finishing off Balsa Steel, just need to actually get the balsa wood to mount on the sides - it's part timber, part plywood, part balsa wood, means it's solid enough to drive properly without smashing itself up, whilst almost guaranteed to splinter into a million pieces in the first hit. Sorted.
  7. #277
  8. #278
    Plywood is brilliant! Won't stand up to a spinner hit but it's a fun material to use haha
    Or at least, I'm assuming not... maybe I'm underestimating the power of wood as armour!
  9. #279
    If 19th century ships of the line used wood as armor, why wouldn't we?
    Wood is natures own carbonfibre...
  10. #280
    That is very true! Suppose it's just how you mount it, and the thickness that you use of it. I'm going to be mounting it well but not using strong enough material to take a hit so pieces will just fly!
    Might do a competitive wooden bot sometime in the future, seems like it'd be a fun thing to do
