I've got 50mm! (2x2 tho ;P)
Yours is as thick as mine is high lol
On topic, looking solid man. I say go 40mm if you got weight. Purely because you can![]()
Thanks for all the comments!
Just to respond to some questions -
Dave, Thanks! I've got a pair of BotBitz TZ85A's to run the motors (S900 sized I think), on a Turnigy 4S 5000mAh battery, 30C discharge (fused for 100A) and 80mm wheels there abouts, should be pretty nippy I hope!
MrSam, I'll get the actual dimensions when I can, it's about 380x250 for the box itself, and then the shovel itself makes it about 380x380 square-ish. Just estimating of course, but it's quite small, just a tad wider than HardWired I!
Razerdave, I'll be unpopular? That's a shame, I really wanted a form of weaponry on my robotHaha, I'm kidding! Just enough to give a nice blue glow through 40mm thick HDPE, or failing that I'll sandwich them between the two 20mm sides... They're all going to be internally mounted, apart from a single surface mounted green LED (for rule purposes) right next to the fuse (link) which'll just be of the normal variety!
Harry, is it really? I feel like I've overdone it a bit now haha! Massacre's pretty low though, don't think anyone's going to escape that bar! Thanks too, even though I might not even need that much, I'm going to just pile it on all the sides 'till I hit 13.5 kilos! Probably not going to push it up to 13.6 purely because I need to account for differences in my numbers - I don't actually have any scales to properly weigh the robot (bathroom scales just say 'error') so I'm having to weigh it using a luggage hook type thing which could be a little bit out...
Only things I need to get now are the connectors (I don't know if chocolate blocks will cause me to fail the tech check) and higher gauge wiring so that I'm well within the rules. At the minute, I use twin earth wire or something, which looks up the job but I'm not 100%... Will post pictures and stuff soon!
Also, just as a question to anyone who has a pushbot or a wedge on their machine, how much ground clearance is best for the RoboChallenge arena? The whole machine has quite a large amount of clearance at the back (it actually has a slight slant forward, so technically it's a wedge I guess) but it has some at the front still, not being flush with the floor - is it best to have a zero ground clearance or to have at least a little bit so it doesn't get caught on the floor panels?
Highest part of the ground clearance on Satanix is 5mm, only been beached once, that was on the pit lid, but not sure if I was stuck on it, or a random bolt.
Ah, I see - I've got a lot more than that at the back (8mm) so I think I'll be alright on that one!
Is the front of Satanix a zero ground clearance for the wedge parts?
Yeah, the wedges sat on the ground, but the robot did wheely, hence I added the hinged ones, they remain in contact with the floor when the robot rocks (soon to be held down with magnets).
Might have to make a slight adjustment to my front then, I have a bit of clearance at the front, probably not going to end well for me 9 times out of 10! For the next version of this, I might implement a similar system, not really got time to do it now but I can see that'd be pretty useful...
I have no doubts that my machine won't be able to get underneath other machines as efficiently as other pushers, but hopefully I'll be able to put up a fight!
Slight update, stainless steel plate still not here, however I am going to make a baseplate from a side of dishwasher and see how that stands up, probably not well but then I can use it as a template!
As a sidenote, work has slightly begun on my new beetleweight, which I'm provisionally calling Abandon because it sounds cool, hopefully that's not been taken yet... I've started designing it, hopefully to be a full-bodied spinner with a bit of a twist that'll probably make it a force to be reckoned with - more soon!
Looking at a couple of options for active weaponry again for HardWired II, even if it's purely for the aesthetic value. Most likely thing at the minute is some kind of spinning thing, powered by a car fan motor if I can find one cheap (and I mean, dead cheap...) Either that or a rather light drum powered by a drill motor might work - this is probably all going to be interchangeable I should mention. A claw powered by one of the linear actuators I have might work too, though it would literally just be for gripping, not crushing!
Rather late in the day to be changing stuff around, but hopefully it works!
