HardWired 3 update
So, Jarvis made me a little mockup of HardWired 3, and it looks absolutely awesome.
The disc on this one is 150mm, running on a 2:1 ratio from this motor http://www.hobbyking.co.uk/hobbyking...tor_730KV.html which is frankly huge, but big motors are always better, and that'll be a heck of a lot of torque behind the disc.
Dimensions are actually close enough the same as HardWired 2, which is impressive with everything in there, two 270 kv 50mm outrunners for drive (200A brushless ESCs) and batteries for it all. At the minute I think it's all running on 8s, and drive is 100mm wheels on a 5:1 ratio, gives a theoretical top speed of about 21mph, call it about 17 which is fast enough for what I'd need! Small amount of magnetic downforce too, about 5-10kg to help put the power down and prevent it from gyro-dancing with that disc
The armour's all 3.2mm Hardox, and 10mm HDPE on top so should be a brick, with Alumec bulkheads, lands it at about 13kg. Only change I'm thinking of making is the disc being a single-tooth rather than a dual tooth, but I need to learn to single tooth disc a lot better first before attempting that. I also need sleep, so fair warning, I may have misquoted a couple of numbers quite horribly here.
Thanks again to Jarvis/MicroGravity100 for the sketchup model, it's a real hand!
