Thanks for all the comments!
Just to respond to some questions -
Dave, Thanks! I've got a pair of BotBitz TZ85A's to run the motors (S900 sized I think), on a Turnigy 4S 5000mAh battery, 30C discharge (fused for 100A) and 80mm wheels there abouts, should be pretty nippy I hope!
MrSam, I'll get the actual dimensions when I can, it's about 380x250 for the box itself, and then the shovel itself makes it about 380x380 square-ish. Just estimating of course, but it's quite small, just a tad wider than HardWired I!
Razerdave, I'll be unpopular? That's a shame, I really wanted a form of weaponry on my robotHaha, I'm kidding! Just enough to give a nice blue glow through 40mm thick HDPE, or failing that I'll sandwich them between the two 20mm sides... They're all going to be internally mounted, apart from a single surface mounted green LED (for rule purposes) right next to the fuse (link) which'll just be of the normal variety!
Harry, is it really? I feel like I've overdone it a bit now haha! Massacre's pretty low though, don't think anyone's going to escape that bar! Thanks too, even though I might not even need that much, I'm going to just pile it on all the sides 'till I hit 13.5 kilos! Probably not going to push it up to 13.6 purely because I need to account for differences in my numbers - I don't actually have any scales to properly weigh the robot (bathroom scales just say 'error') so I'm having to weigh it using a luggage hook type thing which could be a little bit out...
Only things I need to get now are the connectors (I don't know if chocolate blocks will cause me to fail the tech check) and higher gauge wiring so that I'm well within the rules. At the minute, I use twin earth wire or something, which looks up the job but I'm not 100%... Will post pictures and stuff soon!
